EBoln
5 years agomem_reset_n always is low from DDR3 hard controller
i have ArriaV, DDR3 chips, but after deassert global and soft resets mem_reset_n stay is low. Soft reset generate after 1000 tick on 100MHz clk
What else can affect this signal?
AdzimZM_Altera
5 years agoHi Sir,
I'm Adzim. Thanks for using Intel Community.
According to the KDB here, it's looks like the global and soft resets can only trigger the mem_reset_n signal.
Are you using the example design in your simulation?
If not, can you simulate your IP with the example design?
Which Quartus software that you used?
Adzim
- EBoln5 years ago
I am using 18.1.1 and 20.1 standard edition
