AAnch
7 years agoMaximum Operating frequency: NIOS2 system on Max10
Hi, I have built a NIOS2 based SoC system with most of the IP's used from IP Catalog. The targeted evaluation board for this is the Intel Max10 FPGA Development kit (DK-DEV-10M50-A)o. The system c...
GuaBin_N_Intel
Contributor
7 years agoTo optimize the Qsys interconnect, you can refer to this UG https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/qts-qps-5v1.pdf?wapkw=quartus+handbook+18.1+standard, 8-12 Inserting Pipeline Stages to Increase System Frequency & 8-13 Using Bridges. The first method can be easily applied, just changing one setting, and should give some improved Fmax result but it incurs some latency in the transfer.
