ZBien
7 years agoMAX10 dual configuration IP core
On Intel MAX10 configuration guide - figure 3 describes the way that each one of the two burned images are loaded. Can this process described in figure 3 be done without using the dual configuration ...
ZBien
7 years agoJust to be sure: Is it possible not use the Dual configuration IP in the implementation, but still to have the next process: Trying to load the first image after power up but if a first error occurs then trying to load the second image?
sstrell
7 years agoNo, you need the IP to do this.
#iwork4intel
