10 years agoMAX 10-Triple speed Ethernet IP Megacore
Hello everyone. Can anyone please let me know if MAX 10 is supported by Triple speed Ethernet megacore function or not? I was trying to find out from the documentation but could not find anything. Th...
10 years agoThanky you for your answer. Actually i am trying to send 16 bit data through FPGA to PC. For that i am using a shift register and FIFO before data proceed to ethernet megacore function. There are some files generated from the ethernet megacore function including a instantiate file. If i instantiate my shift register and fifo module inside the ethernet instantiation file is that okay or am i doing anything wrong? Appreciate your kind advice. Thanks
