foft
5 years agoMAX 10 flash controller wrapping mode - non-functional
I've been using the MAX 10 internal flash with success on the 10M08SCU169. I am not using bursts.
I ran out of space on the device and was looking for ways to reduce my resource usage. The IP for ...
- 5 years ago
From the SIgnalTap, I observed that you only provide read signal for 1 clock cycle when you are using burst count of 2. I would recommend you to provide read signal at least 2 clock cycle when you are using burstcount of 2 in wrapping mode.
Please refer to Figure 18 in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
JohnT_Altera
5 years agoHi,
I am not able to compile your design. Could you provide me the testing result of the STP file?
- foft5 years ago
OK, here are the compiled projects.
Note for if you recompile it: I was scripting the convert programming files to add the hex file to the UFM.
I'll send signal tap traces in a subsequent message.
