MAX 10 flash controller wrapping mode - non-functional
- 5 years ago
From the SIgnalTap, I observed that you only provide read signal for 1 clock cycle when you are using burst count of 2. I would recommend you to provide read signal at least 2 clock cycle when you are using burstcount of 2 in wrapping mode.
Please refer to Figure 18 in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
Adding a link to where I saw the logic element utilization notes on incremental vs wrapping:
Also I saw a typo in my message, it should read:
"I thought that perhaps using burst size of 1 was not supported, I changed it to 2 with no improvement."
- foft5 years ago
I forgot to include software versions.
I am running Quartus Lite 20.1.1 under Ubuntu 20.04.1 LTS. I have regenerated the ip this version.
A signal tap capture in vcd format is attached. As can be seen an address and request is provided by the data read stays at ffffffff. I verified that the flash has content, if I flash a sof in incremental mode it works.
So read data valid goes high, but no data...
- foft5 years ago
I switched back to incremental mode and found that it no longer works on the latest ip either! However diffing the file I see this fix is not applied. It is also conspicuously within a burst mode=0 section, which leads me to believe there might be an equivalent needed for when burst mode is enabled.
