LVDS SERDES IP
Hi Yishay
RX and TX shall be independent in selecting internal/external PLL mode. Let me know if you seeing otherwise during compilation.
For SERDES usage, it is always recommended to drive the PLL with dedicated clock.
Eng Wei
Hi Eng Wei ,
{Eng Wei} RX and TX shall be independent in selecting internal/external PLL mode {YM} = according to your datasheet(page 39) should to be both external PLL :
So , Do I need to configure for both (RX & TX IP) external IP
{Eng Wei} For SERDES usage, it is always recommended to drive the PLL with dedicated clock.{YM} = Your recommended is for input serdes clock or also for TX serdes clock ?
Yishay Miller
- EngWei_O_Intel5 years ago
Hi Yishay Miller
The diagram is showing the connectivity we need to have for Tx and Rx if they are configured as external PLL mode, as there are no direct connections between Tx and Rx in the diagram.
Yup, we shall use dedicated clock for both.
Eng Wei
