LVDS SERDES IP no DPA lock in simulation
- 5 years ago
I figured out what the issue was:
I used the example design simulation as a comparison and eventually saw that the example locks only after over 8 us. This seems way longer than what the lock time specification in the device datasheet is specifying.
I then ran my own simulation for that long (before I had only run it up to 4 us as according to the lock time specification that is way more than should be needed) and it does also lock.
I am posting this in case someone else ever runs into this issue.
Thanks for the help along the way.
As stated in my first comment, DPA lock does NOT go high EVER, not at the beginning and still not after 4 us simulation time.
Have you run the simulation I provided at all? The reason I provided it was so you can re-create the issue on your end and help. You can see the issue described clearly in there.
I have already reviewed the LVDS SERDES IP Guide and am following the design recommendations.
Attached is a screenshot of my simulation that shows that non of the serdes channels ever get DPA lock even though the data lines are all constantly toggling.
If you can PLEASE take a look at the simulation and help me understand why DPA lock never happens I would greatly appreciate it.
I have also attached the result of running generate example design hoping this helps.
Thank you!
@AminT_Intel, do you have an estimate when you think you can have an update on this?
Thanks!
- AminT_Intel5 years ago
I understand your frustration and I appreciate your patience. I have looked on your design and I found that there is no data on your DPA SERDES. I would advise you to follow the step on this video: https://www.youtube.com/watch?v=rvAByFs4G7c and let me know if you still run the same issue.
Thank you.
- designEngineer5 years ago
Thanks Amin! I have created the simulation from the example design. In that simulation DPA lock does happen but I can not figure out what the difference is to my simulation that does not get DPA lock.
You said you found there is no data on my DPA SERDES. I don't understand. The screenshot you attached shows that the data inputs are all toggling. Why do you say there is no data? I have changed the data input to match the example design simulations data input (input data high for 1 clock then low for 3 clocks and the data being offset by 90 degree phase from the inclock) but I am still not getting DPA lock in my simulation.
Is there any way you can still help to figure out what the issue in my simulation is and what I need to change to get DPA lock?
Thank you for your help!
I just realized you may mean that when you run the simulation you don't get waveform data for the signal rx_dpa_locked. I don't know why this would be when I run the simulation I do get data for that signal but it is always low. See attached screenshot.
