LVDS SERDES IP no DPA lock in simulation
- 5 years ago
I figured out what the issue was:
I used the example design simulation as a comparison and eventually saw that the example locks only after over 8 us. This seems way longer than what the lock time specification in the device datasheet is specifying.
I then ran my own simulation for that long (before I had only run it up to 4 us as according to the lock time specification that is way more than should be needed) and it does also lock.
I am posting this in case someone else ever runs into this issue.
Thanks for the help along the way.
May I know your OPN and which version of Quartus are you using?
Thank you.
I am using Quartus Pro 20.3.0.158 but Quartus is only used to generate the IP (originally created in Quartus 19 but upgraded with 20.3.0.158) the issue is in ModelSim Intel FPGA starter edition 2020.3.
I am not sure what OPN stands for.
- AminT_Intel5 years ago
OPN is Ordering Part Number. Please provide me your OPN so I can help you further on your inquiry.
Thank you.
- designEngineer5 years ago
Cyclone 10 GX: 10CX085YU484E5G
@AminT_Intel , do you have an estimate on when you could have an update on this?
Thanks!
Thank you for your patience and I hope you are doing well there. Would it be possible for you to provide me a design example?
Thank you.
