designEngineer
6 years agoLVDS Serdes DPA FIFO reset recovery timing violation issue (Cyclone 10 GX)
I am trying to deserialize a 16 bit wide DDR data input running at 676 MHz using an LVDS SERDES IP and get recovery timing violations on the DPA FIFO resets. I am looking for help on fixing those in ...
designEngineer
6 years agoI am not sure I understand the reply. Would you mind describing the problem a bit further? Also, do you have a suggested change to fix the problem?
Thanks!
