PVanL
6 years agoLow latency Ethernet 10R Reference Design. How to modify the behaviour of the testbench?
I understand the "avalon_if_param_pkg" is used to configure the behaviour of the Avalon Interfaces. Eth_register_map_params_pkg to configure the inside of the packet. I want to change the gaps betwee...
Deshi_Intel
6 years agoHi Pieter van Leeuwen,
Intel agent support structure goes by IP area and on a case by case support basic.
For instance, I am supporting Ethernet IP while some other Intel agent is supporting PCIe enquiry.
Unfortunately I am not familiar with PCIe and won't be able to help you out.
My suggestion to you is
- We can close this existing case
- while you can file new forum thread mention about the enquiry support on PCIe then this new case will be routed to Intel PCIe support agent that can provide better assist to you.
dlim
