PVanL
6 years agoLow latency Ethernet 10R Reference Design. How to modify the behaviour of the testbench?
I understand the "avalon_if_param_pkg" is used to configure the behaviour of the Avalon Interfaces. Eth_register_map_params_pkg to configure the inside of the packet. I want to change the gaps betwee...
Deshi_Intel
6 years agoHi Pieter,
I have not hear back from you for sometime.
Hopefully everything goes well at your side.
I am now setting this case to closure.
dlim
- PVanL6 years ago
Hi Deshill, Thanks for asking. I am still working on this, and find every now and them some irrularities, that I normally can solve. Can you help me with the next step: I want to couple the low latency INTEL MAC in the 10GBASE-R Example to the INTEL PCIExpress. The only PCI Express example that I found, is one that communicates to a memory. Do you also have an example that has the PCI Express coupled to the Low Latency MAC? Thanks in advance, Regards, Pieter van Leeuwen
