PVanL
6 years agoLow latency Ethernet 10R Reference Design. How to modify the behaviour of the testbench?
I understand the "avalon_if_param_pkg" is used to configure the behaviour of the Avalon Interfaces. Eth_register_map_params_pkg to configure the inside of the packet. I want to change the gaps betwee...
Deshi_Intel
6 years agoHI,
Can you be more specific on which example design that you are referring to here ?
- Do you have the link to the example design ?
- Or if this is example design generated from certain Intel FPGA IP, then pls share with us which IP and using what setting ?
dlim
