JHaye4
1 year agoLow Latency 10G Ethernet SDC warnings
When building a design with a uni-directional instance of the 10G LL MAC IP core for the Cyclone 10 GX, I see the following warnings when the SDC file is read. The design is receive only. It appea...
- 1 year ago
Then I believe those warnings can be safely ignored.
Kindly let me know if needed further support else I shall close the thread.
Pavee
paveetirrasrie_Altera
1 year agoHi,
Are you seeing any error in design compilation? If the compilation runs successfully, I believe this can be safely ignore. Unless you're seeing errors.
To ease out the debug, you may share with me the design so that I can have look into it too.
Pavee
