Renardo18
4 years agoLow-latency 100G Ethernet l8_tx_ready toggling
I am using the low-latency 100G Ethernet IP (with RS-FEC enabled). I needed to use signal tap to debug something, and I observed the behavior of the Avalon stream interface and I noticed that l8_tx_ready signal is toggling :
-high for 11 clock cycles
-low for 11 clock cycles
(Clock frequency is 390.625MHz).
I thought that this signal was supposed to stay high when I don't send any packets.
Do you know what could cause this ? It impacts my design as it divides the bandwidth by a factor of 2.
