learning Jesd multilink from AN803
- 4 years ago
Hi David,
Good day.
Thank you for your patience.
>there is no ed_synth folder in the extracted project from QAR file. could it be for the 21.3 revision problem? but even
>the project may not work for Quartus 21.3, the directory should exist in the project, right?
Based on the Intel Arria 10 JESD204B design example user guide, we have confirm that the content of ed_synth folder is currently place on the project directory. (1 path higher). This is not a revision problem.
You may refer to the attached picture for file content comparison:
Thank you.
ZulsyafiqH_Intel
Hi David,
Good day.
Thank you.
ZulsyafiqH_Intel
