nikhl
4 years agokeernel_system.qsys file is missing
I am trying to create the channels and FIFO for the intel arria 10 PAC card for BSP "a10_ref" by following the link provided below. After creating the clocks in the board.qsys file, At the fo...
EricMunYew_C_Intel
4 years agoThe kernel_system.qsys is not created because you haven't compiled a kernel without regenerating the custom platform. This is to verify the functionality of the existing reference platform. You may refer to below.
nikhl
4 years agoHi Eric,
I have compiled a kernel without regenerating the custom platform, It generated all the files of vector_add except the kernel_system.qsys file. I tried to compile the top.qpf generated by the command "aoc vector_add.cl --no-interleaving" to check the timing and RTL netlist , it is giving errors as shown in the image attached below.
Basically i am trying to create channels in the BSP to share data between two FPGAs
- EricMunYew_C_Intel4 years ago
You may refer to the attached for regenerating the BSP and kernel for OpenCL.
