JESD204B Rx Phase Compensation FIFO full
- Andy7 years ago
Hi Nathan,
Thanks for the response. Don't worry about the delay in replying, I imagine keeping on top of all the forum posts is quite a task.
Since posting I've managed to get the JESD204B link reliably connecting. There were two issues. The first is I had the reset controller IP incorrectly configured. I had the clock frequency parameter wrong (an embarrassing mistake that one!). Second, I have now implemented a PLL to generate the rxlink_clk.
Originally I had a 125MHz clock coming into the FPGA that was driving both the pll_ref_clk and the rxlink_clk (this still didn't work with the reset controller parameter corrected).
I've now changed that external clock source to 250 MHz. I've reconfigured the JESD IP for a 250 MHz clock and (as stated above) added a PLL to generate 125 MHz from the 250 MHz for the rxlink_clk.
In all cases, rxphy_clk is unused/disconnected.
I am using JESD204B subclass 1. I don't understand the problem with my original clock connections, with the same 125 MHz clock connecting to both pll_ref_clk and the rxlink_clk.
Andy
