ONors
5 years agoJESD204B debug
I have a custom board which uses JESD204B to receive samples from a ADC. I have two such boards. On one of them JESD204B works as expected, on the other it does not. On the board that is not working ...
CheepinC_altera
5 years agoHi,
Thanks for your update. Would you mind to share me the signaltap files? I am not familiar with analyzing the VCD files.
One debug test that you can look into to further narrow down the problem location is creating a duplex JESD instance, enable the serial loopback, send data from TX to RX and see if RX is able to achieve link up. This could help to isolate if it is within FPGA or ADC related.
Thank you.
- ONors5 years ago
Here is the stp-file with logged data from both the failing and the working board.
