JESD204B (Agilex F-Tile) v1.0.0 - Support Logic Generation Error (Quartus 22.1)
- 4 years ago
Hi Toby,
Good day.
Thank you for your patience.
>Is this an issue with the 22.1 release?
At the moment, there is no known issue such as the error(21842).
We have tried with Intel® Quartus® Prime Software version 22.1 from our side but did not manage to replicate the error.
We suggest you to try generate our design example as per the JESD204B Intel® Agilex™ FPGA IP Design Example User Guide to see if this error still happen.
If the error still occur, please do attach your design here for us to have a look.
Thank you.
ZulsyafiqH_Intel
Hi Toby,
Good day.
Thank you.
ZulsyafiqH_Intel
Hi Zul,
Looks like the comments about support logic generation above were not relevant. This issue is specifically related to the example design generation failure. My colleague has been able to replicate this on Windows using the 22.1 'Complete Download' (I used the 'Individual Files'). I can confirm that this works correctly under Linux so this issue appears to be specific to Windows.
The design example user guide that you posted is for the E-Tile version of the IP and doesn't appear to have been updated for the F-Tile variant. Do you know if there is a separate document to cover this?
We are still looking for a resolution to this as our development team is using Windows. Is it possible to clear the accepted solution on this post as it has not been resolved?
Toby
