JC_FPGA
7 years agoJESD204B - which modules can be reused from the example design for a single transceiver configuration?
I'm using the Cyclone V GT development kit and have the JESD204B example design up and running. The example design uses 4 transceivers. My use case only requires 1 transceiver. I've used the JESD2...
Nathan_R_Intel
Contributor
7 years agoHie,
Intel-PSG has already provided a script to run simulation in our Design Example generated using Quartus. Hence, for customized test case, you will need to reverse engineer from the library files used to identify the top modules.
The instructions to run simulation is available in our user guide (pg 41 onwards);
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_jesd204b.pdf
Nathan
