WGith
7 years agoJESD IP settings and RX Interrupt Access
Hi, We are using the JESD IP core in the following confirguartions LMF: 812 & 412. We have this working with no problems. We recently tried to change to using LMF: 822 as we are interfacing with ...
WGith
7 years agoNathan,
I was able to get the design working! I decided to regenerate the JESD IP from scratch and inputted all the parameters as expected. I also made sure to use the latest version of quartus 18.1.2 Build 277. This worked, so I am sticking with it!
Thank you for your help.
--Will
