12 years agoJESD IP core: Same link clock shared between all transciever lanes
Hi All, Is it possible to use a common external reference clock for L lanes transceivers in JESD 204 IP core??or do we need separate external reference clock for each sets of lane?? Thanks...
12 years ago --- Quote Start --- Is it possible to use a common external reference clock for L lanes transceivers in JESD 204 IP core??or do we need separate external reference clock for each sets of lane?? --- Quote End --- Did you look at the JESD204B standard? http://www.jedec.org/sites/default/files/docs/jesd204b.pdf (You have to register, but the standard is free) The links are encoded, so in general you could create a system with reference oscillators, and allow the clock-and-data recovery unit to track any phase/frequency-shifts between those oscillators, just as you would in a network setup. However, if you are using multiple ADCs, and those ADCs are synchronous, then its just as easy to use a common reference clock for all the ADCs and FPGAs. Analog Devices has an article on JESD204B http://www.analog.com/static/imported-files/tech_articles/jesd204b-survival-guide.pdf What are you trying to do? Cheers, Dave
