EZhan
6 years agoI've instantiated a HDMI RX interface. it only can receive standard 1080P and 4K format. for a special 2K format(resolution 2560*1080), it cannot be parsed. Any different settings for this special resolution or it's just the feature?
Deshi_Intel
6 years agoHi,
I checked this 2560x1080p resolution. It's ultra wide screen format 21:9 but is supported by HDMI
Typically blank screen/no output on monitor is due to insufficient HDMI bandwidth
- HDMI 2.0 support max BW of 14.4Gb/s
- You can use below BW calculator to estimate the required HDMI BW to ensure it's less than 14.4Gb/s
- https://k.kramerav.com/support/bwcalculator.asp
- Key in Total horizontal pixel = 3000, Total vertical pixel = 1100
- Then you can play around with the colour depth setting and refresh rate setting. Keep it low
- Try out the actual experiment in hardware to see if it helps by reducing bit per colour (disable/turn off deep colour setting) and reduce refresh rate on your GPU graphic card
The other thing is may I know how you convert the monitor EDID file into the Quartus hex file ?
- Do you still have the original EDID hex file dump from monitor so that I can verify using below EDID reader ?
- http://www.edidreader.com/
Lastly I don't have ultra wide screen monitor to help you validate this special video resolution.
- Unless you can share with me your full Quartus design and explain your system setup to me then only I can explore whether I have the similar setup to help you test it
dlim
