RamaMohan
7 years agoIssue with PCIe HIP(A10) Gen3 model behavior in simulations with serial interface
Hi, We are facing an issue in simualtions, with the data transmitted from PCIe hard-IP model during initialization while switching from Gen1 to Gen3 Speed. The model being used is the one for A10 F...
Nathan_R_Intel
Contributor
7 years agoHie RamaMohan,
Yes it is not difficult to generate the End Point library files from .ip files; but wanted to check the exact library files. Even similar Quartus versions with patch or updates could have different library files.
Anyway, I will need to update my available BFM to be Gen3 capable and attempt to replicate this issue on myside.
I will be out from 7th to 13th December. Hence, please expect my next response only after 14th December 2018.
I will need the following information from you.
i. Have you installed any patch or update to Quartus Prime 17.1
ii. Which tool are you using for simulation
Nathan
