RamaMohan
7 years agoIssue with PCIe HIP(A10) Gen3 model behavior in simulations with serial interface
Hi, We are facing an issue in simualtions, with the data transmitted from PCIe hard-IP model during initialization while switching from Gen1 to Gen3 Speed. The model being used is the one for A10 F...
Nathan_R_Intel
Contributor
7 years agoHie,
I will to duplicate the issue in-house to debug further. Could you provide your simulation files (zipped). In the meanwhile, can you the following:
- disable fast_sim
- ensure following are disabled in your Arria 10 Hard IP for PCIe under Phy Characteristics tab:
- Enable Rx polarity inversion soft logic
- enable soft DFE controller IP
If not, please disable it and retry simulation.
Also change the Requested equalization Far end Tx Preset to Preset 0 if you are recompiling.
Nathan
