Matt1
5 years agoissue in routing HPS I2C to FPGA in A10 SoC
I have a requirement to route the I2C(master) in HPS to FPGA and connect the I2C signals to an I2C slave IP(IO Expander logic).I tried to in the following way
under parameter(hard processing...
Eliath_G_Intel
5 years agoHello Nithin,
Yes, SCL is provided by the master.
SCL is not only the clock, it is also used to receive the acknowledge signal from the slave.
-Eliath Guzman
- Matt15 years ago
hello Eilath,
yes the clock should be supplied from the master,
here is my point ,when we route the I2C from HPS to FPGA we have the following signals available
since SCL signal is specified as input , then it can only receive the clock, it cannot drive any clock!!
So what I understand from the port list is that, the IP is a slave.
I am looking for the Master I2C from HPS ,accessible to FPGA to connect to a slave in FPGA.
*I think, SDA signal receive the acknowledge signal from the slave, not the scl.
