XQSHEN
6 years agoIs this the bug of altmemddr IP of intel
In the platform designer, the ip of altmemddr for ddr2, the signal type of external_connections (local_init_done, reset_phy_clk_n) shares the same name is export, it raises error if this conduits con...
XQSHEN
6 years agoYour are right. They should be match, but this ip conduit with 3 signal marked with export, then you can not map with each output. This is the my concern.
In the below picture, the test_manager_0.ddr_status is defined by me with conduit, local_init_done, and reset_phy_clk_n.
