XQSHEN
6 years agoIs this the bug of altmemddr IP of intel
In the platform designer, the ip of altmemddr for ddr2, the signal type of external_connections (local_init_done, reset_phy_clk_n) shares the same name is export, it raises error if this conduits con...
sstrell
6 years agoWhat are the error messages? Can you show the conduit(s) that you are trying to connect this conduit to? Normally, to connect a conduit to a conduit in a system, the signal names must match, as you say. Without seeing the other side or the error messages you're getting, it's hard to diagnose.
#iwork4intel
