XQSHEN
6 years agoIs this the bug of altmemddr IP of intel
In the platform designer, the ip of altmemddr for ddr2, the signal type of external_connections (local_init_done, reset_phy_clk_n) shares the same name is export, it raises error if this conduits con...
XQSHEN
6 years agoYou can see from below picture. There external_conduits of altmemaddr includes 3 outputs , all below 3 outputs use the same signal type is export. I would like to connect these 3 output to other modules inside this NIOS system, it will reports error message because they shares the same name of signal type. I expect there should be no issue if they name it differently, but I can not change this ip.
