XQSHEN
6 years agoIs this the bug of altmemddr IP of intel
In the platform designer, the ip of altmemddr for ddr2, the signal type of external_connections (local_init_done, reset_phy_clk_n) shares the same name is export, it raises error if this conduits con...
sstrell
6 years agoI'm not sure I understand. A conduit (or any interface) is exported from a Platform Designer system and is made up of one or more unique signal names that you connect to other parts of your Quartus project or connect directly to I/O pins. When you export any interface (including a conduit) in Platform Designer, you enter a unique name and the individual signals of the exported interface are prefixed with this unique name. Can you post a screenshot of what you are seeing?
#iwork4intel
