HTong1
7 years agoIs there a way for CvP over PCIe to do CvP update?
Reading the CvP over PCIe, it looks like Intel has moved away from CvP Update Mode for all PCIe Gen3 IP and the Arria 10 does not support CvP Update at all for any PCIe Gen. Is there a way to use the...
HTong1
7 years agoYes, but these 2 partitions are only logic partitions. The ug_cvp.pdf never mentions any physical partition requirement, which is a big difference. That said, if ug_cvp.pdf document is defective in the way that it mistakenly omits the physical partition requirement, then Intel may have never supported true CvP Update. What is documented in ug_s10_cvp.pdf is the same as the PR thru PCIe in Arria 10 except that s10 does not require insertion of PR controllers, both requires physical partition, which is bad.
