HTong1
7 years agoIs there a way for CvP over PCIe to do CvP update?
Reading the CvP over PCIe, it looks like Intel has moved away from CvP Update Mode for all PCIe Gen3 IP and the Arria 10 does not support CvP Update at all for any PCIe Gen. Is there a way to use the...
JohnT_Altera
7 years agoHi,
This is the only way that has always been use even in V series device. The reason that we need to split the partition between the core and periphery is so that you are able to just recompile the core partition without impacting the periphery design. If this is not being performed then CvP will not work as user might be accidentally make changes on the periphery image where it will impact the CvP update.
