SSmit7
6 years agoIs the channel indicator byte (0x7C) in the SPI IP Core guaranteed?
I have implemented the SPI to Avalon-MM IP core in my MAX10 design. While running stress tests on the data transfer between a processor and the MAX10, there is a very rare situation where the channel...
Rahul_S_Intel1
6 years agoHi Ssmit,
The above suggestion is to rule out external factors, some times the data misalignment will be caused by power . If the FPGA is not utilizing much power , we can rule out . Is the SPI ip is from third party vendor
