Is it possible to instantiate a Qsys IP from a newer version of Quartus in an older versioned project?
Hi VCham,
It is not possible to use EPCQ-A with Quartus 17.0.2 build. Plus, you are using ASMI Parallel II IP which not IP Compatibility.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf
Therefore, you need to regenerate IP core and programming file.
However, if you use a legacy device that is not supported in the Intel Quartus® Prime software version 17.1 and later, the Quartus 13.1 Version have patches available to download which add EPCQ-A support to legacy Quartus releases.
https://www.intel.com/content/www/us/en/programmable/products/configuration-devices/support.html#software-download
- VCham6 years ago
Thank you for your response. However, I have some questions. What do you mean by "if you use a legacy device"?
Could you give me an example of that use case?
- ShafiqY_Intel6 years ago
Hi VCham,
"if you use a legacy device" means the device that is not supported in Quartus 17.1 version.
For example
- Cyclone III device (last Quartus support this device is Quartus 13.1)
- Arria II device (last Quartus support this device is Quartus 14.1)
- VCham6 years ago
Ohhh okay I understand.
We are using Cyclone V so that isn't the case for us. We also require that the Quartus release we use be Functional Safety Certified and I believe 13.1 is not unfortunately.
Hi VCham,
I think the best option for you is migrate to Quartus 17.1 version.
- USo006 years ago
Hi ShafiqY_Intel,
Will Quartus 17.1 (or other newer versions) be added to the Functional Safety Data Package (FSDP) any time soon?
We will also run into the same problem. The latest FSDPv5.1 only includes Quartus v17.0.2, which doesn't support the EPCQ-A devices.
I had been wondering if the patch to add EPCQ-A support to legacy Quartus versions would work for legacy versions other than v13.1, but from your answers, that doesn't seem to be the case.
If there's no other workaround for this, we'll have to add hardware provisions for PS mode configuration and not use an Intel Configuration Device (at least in the production version).
We could use a newer version of Quartus that supports EPCQ-A during initial FPGA development in AS mode and then once our microcontroller FPGA firmware upgrade feature has been developed, we could go back to v17.0.2 for functional safety and change to PS mode configuration.
Is there any other way to support EPCQ-A using Quartus v17.0.2 since we are restricted to this version for functional safety?
