ADufl
6 years agoIs it allowed to connect two pll inclk0 to the same input clock ?
Hi, I have a design on a EP4CE40 FPGA where I instantiated a second pll and mapped the inclk0 input to the same input clock as the first one. I get a Critical Warning (176598): PLL "pll3:inst_pll2|a...
- 6 years ago
Hi ,
I done the below analysis from my side to debug the issue .
- Remove the pin constraints from the assignment editor , to isolate any pin mapping issue : But I found warning is present
- Analyzed the PLL logic in the design and found that same clock is been connected to to two pll by using altclkctrl
- The out put frequency from two pll, not allowing to merge together
- So the input pin for the both pll is same , that makes the quartus to assign two different pll one is near to the input pin other little bit far as there is no pll available neart to the input pin .
- This makes the reason for the warning .
- And also I am kindly requesting to check the timing of the design
Rahul_S_Intel1
6 years agoHi ,
Can you please send a sample project which i can replicate the same here, it will be easy for me to debug the issue .
- ADufl6 years ago
Yes. I will provide such design next week.
Thank you.
