SSD001
7 years agoIP-TRIETHERNET AND IP-TRIETHERNETTF
I would like to know the difference between the Triple speed ethernet IPs IP_TRIETHERNET and IP - TRIETHERNETTF.I would like which IP supports MAX10 device.
SSD001
7 years agoHi dlim
The one highlighted (refer to the pic you attached )by you is the IP present in MAX10 (10M16SAU169I7) that i am configuring but the IP requires license to generate the programming file. From my enquiry i came to know that there are two versions of TSE IP exists for purchase but i could not any more info about the IP. If you know kindly let me know.
