IP path missing in Quartus 17.0 Qsys
- 6 years ago
You can set IP paths in both Platform Designer and the main Quartus software, also from Tools->Options. Are you able to set IP paths in Quartus? You can set global or project specific paths there.
In Platform Designer, are you saying that when you go into the Options dialog, the paths you had set previously are simply gone? Very strange.
#iwork4intel
#iwork4intel
- VCham6 years ago
Setting it from the Quartus window seemed to do the trick.
But yes, all the paths I had previously designed were missing, and when I tried to set them via the Platform Designer, they wouldn't actually save.
