Michael_B_Intel
7 years agoIP Core compile error
Hello, I'm using ATX PLL, PHY IP and IOPLL IP for a proof of concept of a transceiver project. The IP core was successful in generation without any errors/warnings. My VHDL files are without any c...
- 7 years agoHI Michael, Is this the Quartus synthesis compilation error ? I can help take a look on the error message if you can attached your quartus design archived QAR. You can also try start build new Quartus project from scratch and see whether the issue still persist or not. Sometime the IP database files may get corrupted and caused error. Thanks. Regards, dlim
Deshi_Intel
dlim
