yt_liu
6 years agoInterfacing the DSP IP cores with Nios ii processor using Avalon-ST
I have successfully built a microphone signal filter using the CIC and FIR DSP IP cores, and now I want to store the output of the FIR filter to a Nios ii processor's main memory. I'm doing this in o...
- 6 years ago
Thanks for your update. Sorry as I am not really a design expert and could not really comment on the right memory IP to use. However, depending on the size of memory required, you can explore into normal FIFO, on-chip memory ie ROM/RAM and also DDR IP. Note that you would still need to create some glue logic to perform the conversion on your own.
Chee Pin
CheepinC_altera
6 years agoI believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
