yt_liu's avatar
yt_liu
6 years ago
Interfacing the DSP IP cores with Nios ii processor using Avalon-ST
I have successfully built a microphone signal filter using the CIC and FIR DSP IP cores, and now I want to store the output of the FIR filter to a Nios ii processor's main memory. I'm doing this in o...
  • CheepinC_altera's avatar
    6 years ago
    Thanks for your update. Sorry as I am not really a design expert and could not really comment on the right memory IP to use. However, depending on the size of memory required, you can explore into normal FIFO, on-chip memory ie ROM/RAM and also DDR IP. Note that you would still need to create some glue logic to perform the conversion on your own.
    Chee Pin
