Interfacing the DSP IP cores with Nios ii processor using Avalon-ST
- 6 years ago
Thanks for your update. Sorry as I am not really a design expert and could not really comment on the right memory IP to use. However, depending on the size of memory required, you can explore into normal FIFO, on-chip memory ie ROM/RAM and also DDR IP. Note that you would still need to create some glue logic to perform the conversion on your own.
Chee Pin
As I understand it, you are trying to interface between the FIR IP and the SDGMA core directly. Sorry as I am not aware of direct way for this. Probably you might need to look into storing the FIR output into some memory and then create some logic to convert it into SDGMA compatible format.
Chee Pin
- yt_liu6 years ago
Hi Chee Pin, your understanding is exactly correct! Thanks for the information. Do you have any suggestions on what memory IP core I should use in order to both store the data from the FIR IP to it and provide a Avalon-MM interface (I guess?) for the SGDMA module? Thanks.
