SSikk
6 years agoIntel P-Tile Avalon-MM for PCI Express Gen3 x16 write transaction in Quartus 19.3 tool for Stratix-10Dx Device
Our design is integrated with Intel P-Tile AV-MM for PCI Express and On Chip RAM. PCIe is configured as Gen3x16,512 bit. We are writing 64bytes into OCR (in single write) from PC over PCIe-BAM AVMM M...
SengKok_L_Intel
6 years agoHi,
To understand this issue further, it will be helpful if the following info is available:
- Do you observe a similar behavior when performing a single 128 bytes write?
- Does the same behavior happen for memory read?
- Can you please capture the following signals to determine if there is more than one memory write TLP received? The trigger condition is the rising edge of *_sop_o.
- p0_rx_st_ready_i
- p0_rx_st_sop_o
- p0_rx_st_eop_o
- p0_rx_st_data_o
- p0_rx_st_valid_o
- p0_rx_st_empty_o
- p0_rx_st_hdr_o
- p0_rx_st_tlp_prfx_o
- p0_rx_st_bar_range_o
- p0_rx_st_tlp_abort_o
- p0_rx_par_err_o
Regards -SK
