Intel FPGA IP Evaluation Mode Issue
Hi David,
The error is due to you have no license for that core to evaluate. You can request a temporary 60-days evaluation license. Kindly contact your local sales representative or distributor. https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
- DLync76 years ago
Has this changed recently?
I used to be able to generate time limited .SOF files without needing any license with the Intel FPGA IP Evaluation Mode turned on. I was definitely using the NIOS II/f and Triple Speed Ethernet Core in a tethered evaluation mode either in Quartus Pro 18 or 19
- DLync76 years ago
Is there any update on this?
Going forward is the only way to generate time limited SOF files is with 60 day evaluation licenses by requesting from distributers?https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/q-and-a.html#a_01 This FAQ still says that a license is not required to evaluate Intel IP and AN320 has not been updated since Quartus 17.1
