Intel FFT IP example design available ?
- 6 years ago
As I understand it, you have some inquiries related to Natural and Digit Reverse for the FFT output. At high level, when there is digit reverse at the FFT output, the sequence of the output samples will be re-arranged. The new sequence is determined by reversing each sample's index bits. For further information and better illustration, you can refer to the following link with examples and sample code:
https://www.mathworks.com/help/signal/ref/digitrevorder.html
Hopefully this is helpful. Thank you.
I believe the initial inquiry has been addressed. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
