Intel FFT IP example design available ?
- 6 years ago
As I understand it, you have some inquiries related to Natural and Digit Reverse for the FFT output. At high level, when there is digit reverse at the FFT output, the sequence of the output samples will be re-arranged. The new sequence is determined by reversing each sample's index bits. For further information and better illustration, you can refer to the following link with examples and sample code:
https://www.mathworks.com/help/signal/ref/digitrevorder.html
Hopefully this is helpful. Thank you.
I notice that you have another inquiry related to FFT example design generation. As a workaround, you can try to generate a simulation example design for FFT IP in older Quartus standard edition ie Q17.0. You can configure your FFT IP and then click on Generate Example Design.
Chee Pin
