User1582192733150209
6 years agoIntel FFT IP core timing issue
Hello Sir/Madam,
I am simulating the intel FFT IP core, and seems FFT output has some timing issue .
Quartus prime pro 17.1
Modelsim-intel starter 10.5c
Windows 10 pro
Arria10gx
FFT con...
tessellation
6 years agoI have the exact same issue implementing the FFT with a cyclone V with quartus lite. Although for my implementation i need to pause the FFT stream between packets for 144 clk cycles only. Hence, the solution provided here won't help me.
6 years agoHi tessellation,
thanks for your reply.
I have tried 2 another solution to solve IPG issue for now, both of them not perfect.
solution 1
install 2 FFT core in parallel and switch input packets to 2 fft core alternately, by such arrangement you will not see any IPG issue, IPG can be 0. cost is FFT resource doubled.
solution 2
change output order to digit reverse, then you will not see IPG issue, but cost is you need other logic to do re-order work.
best regard
Jim
- tessellation6 years ago
Thanks Jim, very helpful
