User1582192733150209
6 years agoIntel FFT IP core timing issue
Hello Sir/Madam,
I am simulating the intel FFT IP core, and seems FFT output has some timing issue .
Quartus prime pro 17.1
Modelsim-intel starter 10.5c
Windows 10 pro
Arria10gx
FFT con...
SengKok_L_Intel
6 years agoHi,
Yes, I can see the same problem in v20.1, and will feedback to the Intel FPGA FFT IP engineering team.
For the moment, you may increase the inter-packet gap number to work around the issue. For example, you can change the IPG_number to 256 in your testbench.
Regards -SK
6 years agoHi SK,
Thanks for your reply.
because I am using intel PAC arria10gx card, which is suggested to use Quartus 17.1 only since other version is not suppoted.
Making a IPG gap bigger might solve the issue , I can try this to see how is going.
thanks
Jim
