DZuck1
7 years agoIntel DisplayPort Arria 10 Sample Project Not Simulating Correctly in Aldec Active-HDL
Hi, I am trying to simulate the Intel DisplayPort Arria 10 Sample Project(Quartus Prime v17.0) in Aldec Active-HDL (v10.3 64 bit) and don't think the simulation is working correctly. The testbench...
BoonT_Intel
7 years agoI found that turn on Support CTS test automation in both Sink and Source will give a value to CRC. Tried this with modelsim and it is working now.
# Testing bpc = 1
# Testing Video Input Frame Number = 04
# Testing Video Input Frame Number = 05
# Testing Video Input Frame Number = 06
# Testing Video Input Frame Number = 07
# Testing Video Input Frame Number = 08
# Testing Video Input Frame Number = 09
# Testing Video Input Frame Number = 0a
# SINK CRC_R = 1015, CRC_G = 1015, CRC_B = 1015,
# SOURCE CRC_R = 1015, CRC_G = 1015, CRC_B = 1015,
# Testing Video Input Frame Number = 0b
# Pass: Test Completed
DZuck1
7 years agoI found the same:
# KERNEL: Testing Link HBR2 Rate Training Pattern 3
# KERNEL: TX Frequency Change Detected, Measured Frequency = 135 MHz
# KERNEL: RX Frequency Change Detected, Measured Frequency = 135 MHz
# KERNEL: End Testing Link HBR2 Rate
# KERNEL: Testing bpc = 1
# KERNEL: Testing Video Input Frame Number = 07
# KERNEL: Testing Video Input Frame Number = 08
# KERNEL: Testing Video Input Frame Number = 09
# KERNEL: Testing Video Input Frame Number = 0a
# KERNEL: Testing Video Input Frame Number = 0b
# KERNEL: Testing Video Input Frame Number = 0c
# KERNEL: SINK CRC_R = 9b40, CRC_G = 9b40, CRC_B = 9b40,
# KERNEL: SOURCE CRC_R = 9b40, CRC_G = 9b40, CRC_B = 9b40,
# KERNEL: Testing Video Input Frame Number = 0d
# KERNEL: Pass: Test Completed
Thank you for the help!
