DZuck1
7 years agoIntel DisplayPort Arria 10 Sample Project Not Simulating Correctly in Aldec Active-HDL
Hi, I am trying to simulate the Intel DisplayPort Arria 10 Sample Project(Quartus Prime v17.0) in Aldec Active-HDL (v10.3 64 bit) and don't think the simulation is working correctly. The testbench...
BoonT_Intel
7 years agoI found that turn on Support CTS test automation in both Sink and Source will give a value to CRC. Tried this with modelsim and it is working now.
# Testing bpc = 1
# Testing Video Input Frame Number = 04
# Testing Video Input Frame Number = 05
# Testing Video Input Frame Number = 06
# Testing Video Input Frame Number = 07
# Testing Video Input Frame Number = 08
# Testing Video Input Frame Number = 09
# Testing Video Input Frame Number = 0a
# SINK CRC_R = 1015, CRC_G = 1015, CRC_B = 1015,
# SOURCE CRC_R = 1015, CRC_G = 1015, CRC_B = 1015,
# Testing Video Input Frame Number = 0b
# Pass: Test Completed
- DZuck17 years ago
I found the same: # KERNEL: Testing Link HBR2 Rate Training Pattern 3 # KERNEL: TX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: RX Frequency Change Detected, Measured Frequency = 135 MHz # KERNEL: End Testing Link HBR2 Rate # KERNEL: Testing bpc = 1 # KERNEL: Testing Video Input Frame Number = 07 # KERNEL: Testing Video Input Frame Number = 08 # KERNEL: Testing Video Input Frame Number = 09 # KERNEL: Testing Video Input Frame Number = 0a # KERNEL: Testing Video Input Frame Number = 0b # KERNEL: Testing Video Input Frame Number = 0c # KERNEL: SINK CRC_R = 9b40, CRC_G = 9b40, CRC_B = 9b40, # KERNEL: SOURCE CRC_R = 9b40, CRC_G = 9b40, CRC_B = 9b40, # KERNEL: Testing Video Input Frame Number = 0d # KERNEL: Pass: Test Completed Thank you for the help!
